[OpenLayers-Trac] [OpenLayers] #3459:
OpenLayers.Style.addPropertyStyles should use
OpenLayers.String.tokenRegEx for matching
trac-20090302 at openlayers.org
Wed Aug 10 09:44:02 EDT 2011
#3459: OpenLayers.Style.addPropertyStyles should use OpenLayers.String.tokenRegEx
for matching
Reporter: jdillmann | Owner: ahocevar
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Style | Version: 2.11 RC2
Keywords: | State:
OpenLayers.Style is using OpenLayers.String.format() to replace attributes
like ${name}.
Unfortunately in OpenLayers.Style.addPropertyStyles() where it is
determined if placeholders are in the style string, it is using a custom
regexp to match them.
It would be better to use OpenLayers.String.tokenRegEx which is used later
to make the actual replacement for the matching in addPropertyStyles.
At the moment one can use OpenLayers.String.format() to replace nested
lists ${a.b} => [a][b]. But this is not working in styles, because the
regexp in OpenLayers.Style won't match a ".".
Another Problem occurs if someone wants to extend the token matching, for
example to match something like: ${addr:street}
This would be really simple if OpenLayers.Style would use the tokenRegEx
While this is no major bug, it is really simple to fix (see patch).
Ticket URL: <http://trac.openlayers.org/ticket/3459>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
