[OpenLayers-Trac] Re: [OpenLayers] #3462: Format/XML.js tests fail in Chromium
OpenLayers trac-20090302 at openlayers.org
Mon Aug 15 12:44:25 EDT 2011
 Reporter:  erilem  |       Owner:
     Type:  task    |      Status:  new
 Priority:  major   |   Milestone:  2.11 Release
Component:  tests   |     Version:  2.11 RC2
 Keywords:          |       State:
Comment(by ahocevar):
 There seems to be a disagreement across the library whether to use
 createElementNS with prefix:localname as 2nd argument, or just localname.
 The proper use of both xmldom.createNode and document.createElementNS,
 which are called by Format.XML::createElementNS depending on which browser
 is used. The API docs of Format.XML::createElementNS demand
 prefix:localname.
Ticket URL: <http://trac.openlayers.org/ticket/3462#comment:3>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
