[OpenLayers-Trac] Re: [OpenLayers] #3462: Format/XML.js tests fail
in Chromium
trac-20090302 at openlayers.org
Mon Aug 15 12:45:56 EDT 2011
#3462: Format/XML.js tests fail in Chromium
Reporter: erilem | Owner:
Type: task | Status: new
Priority: major | Milestone: 2.11 Release
Component: tests | Version: 2.11 RC2
Keywords: | State:
Comment(by ahocevar):
The above comment misses a few words. Here is the correct version:
There seems to be a disagreement across the library whether to use
createElementNS with prefix:localname as 2nd argument, or just localname.
Both is used. The proper use of xmldom.createNode and
document.createElementNS, which are called by Format.XML::createElementNS
depending on which browser is used, is just localname. The API docs of
Format.XML::createElementNS demand prefix:localname.
Ticket URL: <http://trac.openlayers.org/ticket/3462#comment:4>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
