[OpenLayers-Trac] Re: [OpenLayers] #3462: Format/XML.js tests fail
in Chromium
trac-20090302 at openlayers.org
Tue Aug 16 22:48:34 EDT 2011
#3462: Format/XML.js tests fail in Chromium
Reporter: erilem | Owner:
Type: task | Status: new
Priority: major | Milestone: 2.11 Release
Component: tests | Version: 2.11 RC2
Keywords: | State:
Comment(by tschaub):
Replying to [comment:4 ahocevar]:
> The above comment misses a few words. Here is the correct version:
> There seems to be a disagreement across the library whether to use
createElementNS with prefix:localname as 2nd argument, or just localname.
Both is used. The proper use of xmldom.createNode and
document.createElementNS, which are called by Format.XML::createElementNS
depending on which browser is used, is just localname. The API docs of
Format.XML::createElementNS demand prefix:localname.
I'm a bit confused by this comment. Our createElementNS method should be
called with a qualified name (e.g. "alias:foo"). The
[https://developer.mozilla.org/en/DOM/document.createElementNS
createElementNS docs] say second arg is a qualified name (example uses
"html:div") and the [http://msdn.microsoft.com/en-
us/library/ms757901(v=vs.85).aspx#Y87 MS docs] say name should be
qualified for ELEMENT_NODE (see remarks section).
I see that the GeoRSS, KML, ArcXML, and OSM formats use the default
namespace - but I think that "foo" is still a legitimate qualified name.
(And Google Earth demands the default namespace iirc.)
I'm still not seeing Format/XML.html test failures. But I'll try more
browsers.
Ticket URL: <http://trac.openlayers.org/ticket/3462#comment:5>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
