[OpenLayers-Trac] Re: [OpenLayers] #1910: Invalid argument failure
with IE8
trac-20090302 at openlayers.org
Fri Feb 25 02:13:00 EST 2011
#1910: Invalid argument failure with IE8
Reporter: CharlesHarrison | Owner: crschmidt
Type: feature | Status: closed
Priority: blocker | Milestone: 2.11 Release
Component: Layer.Vector | Version: 2.7
Resolution: worksforme | Keywords:
State: Awaiting User Feedback |
Changes (by crschmidt):
* status: reopened => closed
* resolution: => worksforme
Comment:
At this point, I feel reasonably confident that "Invalid Argument" errors
are only the result of attempting to create Vector layers before the DOM
is ready. If someone can still recreate this error against a modern
version of OpenLayers with IE, we can investigate why this might be
happening. The example given here is not simplified, and has way too much
code to figure out what might be going wrong.
In general, creating vector layers should happen onload. Trying to create
them before that will typically result in strange or unwanted behavior.
ahayes reported 20 months ago that the test page provided worked for him.
Checking in IE right now, it also works for me. With no reproducible bug
condition or test case to work off of, there's not much we can do about
this.
Ticket URL: <http://trac.openlayers.org/ticket/1910#comment:46>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
