[OpenLayers-Trac] Re: [OpenLayers] #2085: vectorLayer.addFeatures(null) breaks
OpenLayers trac-20090302 at openlayers.org
Fri Feb 25 02:11:21 EST 2011
  Reporter:  fvanderbiest     |       Owner:  crschmidt
      Type:  bug              |      Status:  closed
  Priority:  major            |   Milestone:  2.11 Release
 Component:  Layer.Vector     |     Version:  2.8 RC2
Resolution:  wontfix          |    Keywords:
     State:  Needs More Work  |
Changes (by crschmidt):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 This behavior is the same behavior as you get from many many other similar
 functions. Though this may not be consistent across the entire library
 (nothing is), I don't think that there's any reasonable argument that can
 be made that there is an obvious expected behavior here, or any reason
 that we need to put this nto this function specifically.
Ticket URL: <http://trac.openlayers.org/ticket/2085#comment:3>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
