[OpenLayers-Trac] Re: [OpenLayers] #2925: Some remarks about #2900: Add Google's closure compiler to build tools
OpenLayers trac-20090302 at openlayers.org
Thu Feb 24 19:35:47 EST 2011
  Reporter:  fbuchinger  |       Owner:
      Type:  feature     |      Status:  closed
  Priority:  minor       |   Milestone:  2.11 Release
 Component:  general     |     Version:  2.10
Resolution:  fixed       |    Keywords:
     State:              |
Changes (by crschmidt):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 fbuchinger: If you can replicate the misbehavior you had with the Java
 jar, I'd be interested. I've implemented support for both the webservice
 and the jar, and I've just grabbed your changes to the webservice support
 to use urllib2. For smaller builds, using closure_ws is fine, and for
 larger builds, you should probably just grab the local jar rather than
 slamming google's service with requests.
 If you can reproduce the syntax error, please open a new ticket in the
 2.11 milestone and assign to me.
Ticket URL: <http://trac.openlayers.org/ticket/2925#comment:1>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
