[OpenLayers-Trac] Re: [OpenLayers] #2936: Handler.Drag: Does not move until the cursor, and does not finish properly.
OpenLayers trac-20090302 at openlayers.org
Sun Feb 27 15:42:27 EST 2011
 Reporter:  jorix         |       Owner:  erilem
     Type:  bug           |      Status:  new
 Priority:  blocker       |   Milestone:  2.11 Release
Component:  Handler.Drag  |     Version:  2.10
 Keywords:                |       State:  Commit
Changes (by crschmidt):
  * state:  Review => Commit
Comment:
 Although it looks like this issue is less likely to be an issue now,
 because the default dragTimeout is 0, with a higher value, I was able to
 see problems in this behavior, and I can confirm that this appears to be
 the correct way to handle the situation -- fixes bugs, doesn't fail tests
 for me, etc.
 There was one problem with applying the patch against trunk, so I'm
 uploading a new version; erilem, you can feel free to commit.
Ticket URL: <http://trac.openlayers.org/ticket/2936#comment:9>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
