[OpenLayers-Trac] Re: [OpenLayers] #3400: Feature modification
management
trac-20090302 at openlayers.org
Mon Jul 4 03:25:31 EDT 2011
#3400: Feature modification management
Reporter: ahocevar | Owner: tschaub
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Format.WFST | Version: 2.10
Keywords: | State: Review
Comment(by bartvde):
Hey Andreas,
a few remarks:
* modified, shouldn't we call this originals or originalValues instead?
To me the modified term sounds misleading, since I would expect it to have
the modified values instead and not the originals?
* with tests/Format/WFST/v1.html I would expect only the geometry to be
written out, since it is the only one in modified? Why are the 2
attributes written out as well? I see it in the code (the check for
feature.attributes), but it's not what I would expect to happen. Or is
this to be backwards-compatible? I guess so, but maybe state it somewhere
in a comment?
* tests/Control/ModifyFeature.html: layer.addFeatures[feature] is missing
brackets
* lib/OpenLayers/Format/WFST/v1.js: should we not also check if the
original and modified values differ?
Respective tests also pass in FF4.
Ticket URL: <http://trac.openlayers.org/ticket/3400#comment:3>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
