[OpenLayers-Trac] Re: [OpenLayers] #2234: We need a format to read
OGC's ServiceExceptionReport
trac-20090302 at openlayers.org
Wed Jun 15 07:34:04 EDT 2011
#2234: We need a format to read OGC's ServiceExceptionReport
Reporter: fvanderbiest | Owner: bartvde
Type: feature | Status: closed
Priority: minor | Milestone: 2.12 Release
Component: Format | Version: 2.8
Resolution: fixed | Keywords:
State: Needs More Work |
Comment(by bartvde):
Hi Andreas, thanks for the comment. However that's not why these tests
were failing, they are however valid reasons for that code statement to
fail as well.
The root problem in this case was that those WFS Capabilities tests have
incomplete GetCapabilities XML snippets:
Engine name: Xerces
Severity: error
Description: cvc-complex-type.2.4.b: The content of element
'wfs:WFS_Capabilities' is not complete. One of
'{"http://www.opengis.net/ows":ServiceIdentification,
"http://www.opengis.net/ows":ServiceProvider,
"http://www.opengis.net/ows":OperationsMetadata,
"http://www.opengis.net/wfs":FeatureTypeList,
"http://www.opengis.net/wfs":ServesGMLObjectTypeList,
"http://www.opengis.net/wfs":SupportsGMLObjectTypeList,
"http://www.opengis.net/ogc":Filter_Capabilities}' is expected.
Start location: 2:2
End location: 2:22
URL: http://www.w3.org/TR/xmlschema-1/#cvc-complex-type
Since the WFS capabilities parser checks for the service attribute to be
equal to "WFS" (I could not come up with a better check at the time) in
order to see if an exception occurred, it runs into the code block for
parsing the exception:
if (capabilities.service === undefined) {
// an error must have happened, so parse it and report back
var format = new OpenLayers.Format.OGCExceptionReport();
capabilities.error = format.read(data);
Ticket URL: <http://trac.openlayers.org/ticket/2234#comment:11>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
