[OpenLayers-Trac] Re: [OpenLayers] #2234: We need a format to read
OGC's ServiceExceptionReport
trac-20090302 at openlayers.org
Wed Jun 15 07:43:00 EDT 2011
#2234: We need a format to read OGC's ServiceExceptionReport
Reporter: fvanderbiest | Owner: bartvde
Type: feature | Status: closed
Priority: minor | Milestone: 2.12 Release
Component: Format | Version: 2.8
Resolution: fixed | Keywords:
State: Needs More Work |
Comment(by ahocevar):
Bart, I'm aware that this is the reason. But there is no reason to change
library code in order to make tests with incomplete mock objects pass,
especially not if additional checks have to be added. When I investigated
the reason for r12084, I saw that there are other good reasons for this
additional check, and my comment in r12085 expains these. But the bottom
line is that changes in the code should go through a review process.
Ticket URL: <http://trac.openlayers.org/ticket/2234#comment:12>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
