[OpenLayers-Trac] Re: [OpenLayers] #3344: specialized layer for a grid of points
OpenLayers trac-20090302 at openlayers.org
Fri Jun 17 14:02:19 EDT 2011
 Reporter:  tschaub       |       Owner:  tschaub
     Type:  feature       |      Status:  assigned
 Priority:  minor         |   Milestone:  2.12 Release
Component:  Layer.Vector  |     Version:  2.10
 Keywords:                |       State:  Commit
Comment(by tschaub):
 Replying to [comment:4 bartvde]:
 >  * why do we add fromBounds if we already have
 OpenLayers.Bounds.toGeometry? I personally don't see a need for both.
 Can you believe I forgot about Bounds.toGeometry (r5625 was a long time
 ago)?  Actually, I think toGeometry should be deprecated and fromBounds
 should be added, but we don't need the bloat at this point.  It makes more
 sense that LonLat and Bounds (lower level) don't know about Geometry
 (higher level).  Whenever we get around to 3.0, this should be reworked.
 For now, I'll rework the patch to use toGeometry.
 >  * why is origin initialized to 0 and not to null? From the docs it's
 not entirely clear to me where the origin is located (bottom-left)?
 I'll update the initial value to be null.  The grid is infinite, so there
 is no bottom/left etc.  The grid lattice will always be aligned with the
 origin.  I'll update the docs to clarify this.  Let me know if you think
 there is a better way to describe it (we could say {{{ (Math.sqrt(Math.pow
 (xp-xo, 2) + Math.pow(yp-yo, 2)) * Math.cos(Math.atan2(yp-yo, xp-xo) - r))
 % dx === 0}}} and similarly for {{{dy}}} for any point (xp, yp) rotation
 (r) and origin (xo, yo)).
 >  * maxFeatures and setMaxFeatures: is maxFeatures not an {Integer}
 always, so why use {Number} in docs?
 I go back and forth on this one.  There's nothing restricting this value
 to an integer, and we only have Number in js anyway.
 >  * make more explicit in docs that dx and dy are in map units and not in
 pixel units?
 Good point, will do.
 >  * in getOrigin shouldn't we protect against getExtent returning null?
 Internally, getOrigin is only called on map {{{moveend}}}, so at that
 point we should have an extent.  If someone calls {{{setSpacing}}} or
 other before adding the layer to a map, things will fail.  I'll add docs
 to clarify this.
 >  * updateGrid misses docs for force
 Added, thanks.
 >  * make it more explicit in the docs that rotation is negative in the
 clockwise direction
 Clarified this.
 > Other than this it's good to go.
 Thanks for the careful review.
Ticket URL: <http://trac.openlayers.org/ticket/3344#comment:5>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
