[OpenLayers-Trac] Re: [OpenLayers] #3368: Make Protocol.WFS work
with just featureType and featurePrefix
trac-20090302 at openlayers.org
Mon Jun 20 04:37:14 EDT 2011
#3368: Make Protocol.WFS work with just featureType and featurePrefix
Reporter: ahocevar | Owner: tschaub
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Protocol.WFS | Version: 2.11 RC1
Keywords: | State: Commit
Changes (by bartvde):
* state: Review => Commit
Comment:
Looks good to go, relevant tests also pass in FF4, with a few
remarks/questions:
* A question about the change you made in
lib/OpenLayers/Format/WFST/v1_0_0.js (and 1_1_0.js as well), are you 100%
that in all cases both prefix and featureNS will be set? Imagine the
probably hypothetical case where only prefix is set, we would get a
prefixed node, but no xmlns declaration leading to invalid XML. Is it not
safer to keep the current code or check for both prefix and featureNS?
* Maybe add a comment to the change in
lib/OpenLayers/Format/Filter/v1_0_0.js stating this will only happen if
you configure geometryName with null, so it's not default behaviour to
create invalid WFS 1.0 requests.
* lib/OpenLayers/Protocol/WFS/v1.js: the comment about default prefix is
this not implementation (i.e. GeoServer) specific? I don't think e.g.
Mapserver has something equivalent to default namespace/workspace. Why not
just state if the prefix matches the prefix of the geometry node's
"featureNode"?
* GML/Base talks about a default value of "geometry", but Protocol WFS
mentions "the_geom". So isn't the default value geometry?
* Put {{{var format = this.readFormat || this.format; }}} before the read
call to simplify.
* Trailing comma in tests/Format/WFST/v1_0_0.html and
tests/Format/WFST/v1_1_0.html
* tests/Format/Filter/v1_0_0.html: typo in test function name
test_BBOX_noGeometrName
* tests/Protocol/WFS.html: trailing comma
* was the change in wfs:Delete made to pass the tests? So this mean we
cannot write out a request anymore with: <ogc:PropertyName/> ? Or would
this require setting geometryName to an empty string?
Ticket URL: <http://trac.openlayers.org/ticket/3368#comment:5>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
