[OpenLayers-Trac] Re: [OpenLayers] #3368: Make Protocol.WFS work
with just featureType and featurePrefix
trac-20090302 at openlayers.org
Mon Jun 20 07:49:06 EDT 2011
#3368: Make Protocol.WFS work with just featureType and featurePrefix
Reporter: ahocevar | Owner: tschaub
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Protocol.WFS | Version: 2.11 RC1
Keywords: | State: Commit
Comment(by ahocevar):
Thanks Bart for the thorough review. Some follow-up questions and
explanations:
Replying to [comment:5 bartvde]:
> * A question about the change you made in
lib/OpenLayers/Format/WFST/v1_0_0.js (and 1_1_0.js as well), are you 100%
that in all cases both prefix and featureNS will be set? Imagine the
probably hypothetical case where only prefix is set, we would get a
prefixed node, but no xmlns declaration leading to invalid XML. Is it not
safer to keep the current code or check for both prefix and featureNS?
I don't see this problem. The typeName attribute of the Query is not a
node, so XML doesn't care what goes in there. Note that the whole point of
this change is to make things work when '''only''' the featurePrefix and
'''no''' featureNS is set.
> * Maybe add a comment to the change in
lib/OpenLayers/Format/Filter/v1_0_0.js stating this will only happen if
you configure geometryName with null, so it's not default behaviour to
create invalid WFS 1.0 requests.
Will do.
> * lib/OpenLayers/Protocol/WFS/v1.js: the comment about default prefix
is this not implementation (i.e. GeoServer) specific? I don't think e.g.
Mapserver has something equivalent to default namespace/workspace. Why not
just state if the prefix matches the prefix of the geometry node's
"featureNode"?
Good point. But it's not just the prefix of the geometry node's
"featureNode", it's "the feature prefix used by the server".
> * GML/Base talks about a default value of "geometry", but Protocol WFS
mentions "the_geom". So isn't the default value geometry?
This really depends on the inheritance chain and the mixins used. I just
used what the docs already said before my change. If you can confirm that
it is "geometry" in this case (which I doubt, because otherwise we
wouldn't have been able to use this with GeoServer ever without setting
the geometryName), I'll change it.
> * Put {{{var format = this.readFormat || this.format; }}} before the
read call to simplify.
I had this already, but changed it back because one read call is with
options and the other without, and I didn't investigate if the options do
harm in the case where we currently don't use them. If you can confirm
that they don't, I'll change it.
> * Trailing comma in tests/Format/WFST/v1_0_0.html and
tests/Format/WFST/v1_1_0.html
> * tests/Format/Filter/v1_0_0.html: typo in test function name
test_BBOX_noGeometrName
> * tests/Protocol/WFS.html: trailing comma
Thanks, will change them.
> * was the change in wfs:Delete made to pass the tests? So this mean we
cannot write out a request anymore with: <ogc:PropertyName/> ? Or would
this require setting geometryName to an empty string?
Yes, this change was made to make the test pass. Do you see any side
effects of this? Would it be desirable being able to serialize a Query
that has an empty PropertyName element? What would be the point of doing
so?
I'm waiting for your feedback before I commit this.
Ticket URL: <http://trac.openlayers.org/ticket/3368#comment:6>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
