[OpenLayers-Trac] Re: [OpenLayers] #3368: Make Protocol.WFS work with just featureType and featurePrefix
OpenLayers trac-20090302 at openlayers.org
Mon Jun 20 08:02:21 EDT 2011
 Reporter:  ahocevar      |       Owner:  tschaub
     Type:  feature       |      Status:  new
 Priority:  minor         |   Milestone:  2.12 Release
Component:  Protocol.WFS  |     Version:  2.11 RC1
 Keywords:                |       State:  Commit
Comment(by bartvde):
 Replying to [comment:6 ahocevar]:
 > Thanks Bart for the thorough review. Some follow-up questions and
 explanations:
 > Replying to [comment:5 bartvde]:
 > >  * A question about the change you made in
 lib/OpenLayers/Format/WFST/v1_0_0.js (and 1_1_0.js as well), are you 100%
 that in all cases both prefix and featureNS will be set? Imagine the
 probably hypothetical case where only prefix is set, we would get a
 prefixed node, but no xmlns declaration leading to invalid XML. Is it not
 safer to keep the current code or check for both prefix and featureNS?
 > I don't see this problem. The typeName attribute of the Query is not a
 node, so XML doesn't care what goes in there. Note that the whole point of
 this change is to make things work when '''only''' the featurePrefix and
 '''no''' featureNS is set.
 You're right, there is no issue, please ignore my previous comment.
 > >  * Maybe add a comment to the change in
 lib/OpenLayers/Format/Filter/v1_0_0.js stating this will only happen if
 you configure geometryName with null, so it's not default behaviour to
 create invalid WFS 1.0 requests.
 > Will do.
 > >  * lib/OpenLayers/Protocol/WFS/v1.js: the comment about default prefix
 is this not implementation (i.e. GeoServer) specific? I don't think e.g.
 Mapserver has something equivalent to default namespace/workspace. Why not
 just state if the prefix matches the prefix of the geometry node's
 "featureNode"?
 > Good point. But it's not just the prefix of the geometry node's
 "featureNode", it's "the feature prefix used by the server".
 > >  * GML/Base talks about a default value of "geometry", but Protocol
 WFS mentions "the_geom". So isn't the default value geometry?
 > This really depends on the inheritance chain and the mixins used. I just
 used what the docs already said before my change. If you can confirm that
 it is "geometry" in this case (which I doubt, because otherwise we
 wouldn't have been able to use this with GeoServer ever without setting
 the geometryName), I'll change it.
 You're right, I had missed that. Though it is kind of confusing to have
 different defaults at different levels, at least it confused me for a
 minute :-)
 > >  * Put {{{var format = this.readFormat || this.format; }}} before the
 read call to simplify.
 > I had this already, but changed it back because one read call is with
 options and the other without, and I didn't investigate if the options do
 harm in the case where we currently don't use them. If you can confirm
 that they don't, I'll change it.
 I had missed that, I think they can potentially harm (e.g. GeoJSON), so
 leave it as you had it.
 > >  * Trailing comma in tests/Format/WFST/v1_0_0.html and
 tests/Format/WFST/v1_1_0.html
 > >  * tests/Format/Filter/v1_0_0.html: typo in test function name
 test_BBOX_noGeometrName
 > >  * tests/Protocol/WFS.html: trailing comma
 > Thanks, will change them.
 > >  * was the change in wfs:Delete made to pass the tests? So this mean
 we cannot write out a request anymore with: <ogc:PropertyName/> ? Or would
 this require setting geometryName to an empty string?
 > Yes, this change was made to make the test pass. Do you see any side
 effects of this? Would it be desirable being able to serialize a Query
 that has an empty PropertyName element? What would be the point of doing
 so?
 Maybe there is a WFS out there that needs PropertyName, but ignores its
 value for WFS 1.0. But I think we can safely ignore until someone files a
 bug with a case that fails.
 > I'm waiting for your feedback before I commit this.
 Thanks for the follow-up questions, seems most of my concerns are not
 valid.
Ticket URL: <http://trac.openlayers.org/ticket/3368#comment:7>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
