[OpenLayers-Trac] [OpenLayers] #3391: TIME parameters Ignored by
WMSGetFeatureInfo Control
trac-20090302 at openlayers.org
Wed Jun 29 09:41:41 EDT 2011
#3391: TIME parameters Ignored by WMSGetFeatureInfo Control
Reporter: geographika | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Control.WMSGetFeatureInfo | Version: 2.10
Keywords: TIME WMSGetFeatureInfo | State:
When a TIME parameter is applied to a WMS layer it could/should also apply
to associated WMSGetFeatureInfo requests. Otherwise it can lead to a user
clicking on an empty map and getting results back when the WMS is not
within the specified TIME range.
A workaround is to use the ''beforegetfeatureinfo'' event and to call the
following function:
function(evt){
var layers = this.findLayers();
if (layers.length > 0) {
var firstLayer = layers[0];
if (firstLayer.params.TIME) {
this.vendorParams = {
"time": firstLayer.params.TIME
Alternatively the buildWMSOptions function in the
OpenLayers.Control.WMSGetFeatureInfo could be updated to check for a TIME
parameter on the first WMS layer and apply this to the request.
Ticket URL: <http://trac.openlayers.org/ticket/3391>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
