[OpenLayers-Trac] Re: [OpenLayers] #3016: ModifyFeature - "del" key press outside vertice should delete the feature
OpenLayers trac-20090302 at openlayers.org
Mon Mar 7 15:17:59 EST 2011
 Reporter:  adube                  |       Owner:  tschaub
     Type:  feature                |      Status:  new
 Priority:  minor                  |   Milestone:  2.11 Release
Component:  Control.ModifyFeature  |     Version:  2.10
 Keywords:  del, delete, key       |       State:  Review
Changes (by adube):
  * state:  Needs More Work => Review
Comment:
 I set the State for this ticket to Review.  Two things are remaining to
 think for now :
  * should an added feature with a state != null trigger the
 "featurestatechanged" event ?
  * should the feature be redrawn or should that be left to do on client-
 side (for example, using the toState("delete") on del key pressed using
 the ModifyFeature control, should the feature be redrawn) ?
Ticket URL: <http://trac.openlayers.org/ticket/3016#comment:6>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
