[OpenLayers-Trac] Re: [OpenLayers] #3046: Popup can't be closed
trac-20090302 at openlayers.org
Fri Mar 11 15:23:53 EST 2011
Reporter: pebXX2346 | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: examples | Version: SVN
Keywords: Popup Strategy BBOX | State: Review
Comment(by pebXX2346):
Replying to [comment:7 jorix]:
> Replying to [comment:6 pebXX2346]:
> > Well, ...
> > This bug is '''not''' about the example!
> > It is a bug in the library...
> > Changing the example where the bug shows is just like
> > destroying a warning light.
> '''I agree with you''', yes!
> But it's not a bug repair what needs, is a major improvement what needs.
> The theme of "Popus" is weak in !OpenLayers. There is much work to
improve what's there.
Also docs with working examples, snippets.
When i became a heavy user (will need some years) i will write some.
> But from the library as now is the example should be written with the
changes I have proposed.
Ok, that may help people who look for code that work's.
> NOTE: I'm not !OpenLayers team.
I'm also not :-)
Just a nearly first time user.
Ticket URL: <http://trac.openlayers.org/ticket/3046#comment:8>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
