[OpenLayers-Trac] Re: [OpenLayers] #3194: Problem with double click to finish a drawing using IE6 (and IE8 without !DOCTYPE)
OpenLayers trac-20090302 at openlayers.org
Wed Mar 30 17:01:13 EDT 2011
!DOCTYPE)
 Reporter:  jorix         |       Owner:  tschaub
     Type:  bug           |      Status:  new
 Priority:  major         |   Milestone:  2.11 Release
Component:  Handler.Path  |     Version:  SVN
 Keywords:                |       State:  Awaiting User Feedback
Comment(by erilem):
 Replying to [comment:3 jorix]:
 > Replying to [comment:2 tschaub]:
 > > I've seen this problem in previous releases.  Is it noticeably worse
 in the trunk than in 2.10?
 > Yes and not. I think now is due to another problem.
 > I think when js works fairly between click and click on the IE (without
 !DOCTYPE or IE6) has trouble detecting the double click. Now it occurs
 again in handler.drag with further improvement: pan while dragging.
 Hi Xavier. I must confess that I'm having a hard time understanding you
 here. I'd appreciate you rephrasing a bit. Thanks.
Ticket URL: <http://trac.openlayers.org/ticket/3194#comment:4>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
