[OpenLayers-Trac] Re: [OpenLayers] #3016: ModifyFeature - "del" key
press outside vertice should delete the feature
trac-20090302 at openlayers.org
Tue May 10 10:43:35 EDT 2011
#3016: ModifyFeature - "del" key press outside vertice should delete the feature
Reporter: adube | Owner: tschaub
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Control.ModifyFeature | Version: 2.10
Keywords: del, delete, key | State: Needs More Work
Comment(by adube):
Eric,
All your proposed modifications were applied, except the use of a "log"
object. Could you please shed some light on how I should change the way I
make my test to your proposed method ?
Ticket URL: <http://trac.openlayers.org/ticket/3016#comment:14>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
