[OpenLayers-Trac] Re: [OpenLayers] #3016: ModifyFeature - "del" key press outside vertice should delete the feature
OpenLayers trac-20090302 at openlayers.org
Tue May 10 11:06:54 EDT 2011
 Reporter:  adube                  |       Owner:  tschaub
     Type:  feature                |      Status:  new
 Priority:  minor                  |   Milestone:  2.11 Release
Component:  Control.ModifyFeature  |     Version:  2.10
 Keywords:  del, delete, key       |       State:  Review
Changes (by adube):
  * state:  Needs More Work => Review
Comment:
 Okay, I guess you meant to use that kind of test in the
 "tests/Layer/Vector.html" file.  I modified the test of "toState" to use
 it.  Ready to be reviewed again.  Thanks a lot again for your tips.
Ticket URL: <http://trac.openlayers.org/ticket/3016#comment:15>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
