[OpenLayers-Trac] Re: [OpenLayers] #3016: ModifyFeature - "del" key press outside vertice should delete the feature
OpenLayers trac-20090302 at openlayers.org
Wed May 11 03:24:06 EDT 2011
 Reporter:  adube                  |       Owner:  tschaub
     Type:  feature                |      Status:  new
 Priority:  minor                  |   Milestone:  2.11 Release
Component:  Control.ModifyFeature  |     Version:  2.10
 Keywords:  del, delete, key       |       State:  Review
Comment(by erilem):
 In [attachment:patch-openlayers-3016-r11965-A4.diff] I've reworked the
 tests a bit. I've also added information in the featurestatechanged event
 doc text, removed {{{this.prevState = null}}} in the {{{Feature.Vector}}}
 constructor, and changed the names of the properties in the event
 ({{{state}}} -> {{{newState}}}, {{{previous}}} -> {{{prevState}}}). Tell
 me what you think.
 Also, without your patch {{{toState}}} does nothing when {{{state}}} is
 {{{DELETE}}} and {{{this.state}}} is {{{INSERT}}}; with your patch
 {{{toState}}} does set the feature state to {{{DELETE}}} in that case. I
 guess you've purposefully changed that behavior, for a
 {{{featurestatechanged}}} event to be triggered in that case. I think it's
 fine, but the application code will need to behave correctly in that case,
 by destroying the feature right away. Do you agree?
Ticket URL: <http://trac.openlayers.org/ticket/3016#comment:16>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
