[OpenLayers-Trac] Re: [OpenLayers] #3016: ModifyFeature - "del" key
press outside vertice should delete the feature
trac-20090302 at openlayers.org
Wed May 11 08:43:39 EDT 2011
#3016: ModifyFeature - "del" key press outside vertice should delete the feature
Reporter: adube | Owner: tschaub
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Control.ModifyFeature | Version: 2.10
Keywords: del, delete, key | State: Review
Comment(by adube):
Replying to [comment:16 erilem]:
> In [attachment:patch-openlayers-3016-r11965-A4.diff] I've reworked the
tests a bit. I've also added information in the featurestatechanged event
doc text, removed {{{this.prevState = null}}} in the {{{Feature.Vector}}}
constructor,
Thanks a lot for those fixes.[[BR]][[BR]]
> and changed the names of the properties in the event ({{{state}}} ->
{{{newState}}}, {{{previous}}} -> {{{prevState}}}). Tell me what you
think.
I agree. It's more verbose that way.[[BR]][[BR]]
> Also, without your patch {{{toState}}} does nothing when {{{state}}} is
{{{DELETE}}} and {{{this.state}}} is {{{INSERT}}}; with your patch
{{{toState}}} does set the feature state to {{{DELETE}}} in that case. I
guess you've purposefully changed that behavior, for a
{{{featurestatechanged}}} event to be triggered in that case. I think it's
fine, but the application code will need to behave correctly in that case,
by destroying the feature right away. Do you agree?
Yes, I agree and you perfectly understood the issued I faced. When I
tried to add new features (state == {{{INSERT}}}) and used the del key to
pop a {{{"Are you sure ?"}}} message using the {{{featurestatechanged}}}
event, the toState was never called, nor the state set to {{{DELETE}}}.
Thanks a lot for your review.
Ticket URL: <http://trac.openlayers.org/ticket/3016#comment:17>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
