[OpenLayers-Trac] Re: [OpenLayers] #3315: Problem with geometry
handlers - doesn't stop showing a point under the cursor
trac-20090302 at openlayers.org
Tue May 24 17:18:04 EDT 2011
#3315: Problem with geometry handlers - doesn't stop showing a point under the
cursor
Reporter: mgleahy | Owner: tschaub
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Handler.Point | Version: 2.11 RC1
Keywords: | State:
Comment(by mgleahy):
Sorry...I was mistaken when I indicated the measurepartial event was being
fired, it's the 'modify' callback on the handler that's constantly being
called in between drawings (likely because of the moving dot). My code
was also using this method so that I could provide measurement feedback on
mousemove events (without having to add additional points to the drawing).
Having modify event being called when no drawing has been created seems
counterintuitive to me, since when the user is not actually drawing the
feature, there is no geometry being modified (unless we count the point
under the cursor). However, thanks for pointing out the new parameter in
the callbacks...I think this is what I'll need to account for the changes
coming in 2.11 for my code.
While I will be able to account for this in my code, I still find that
having a point following the cursor when there is no active drawing being
created may not be appropriate or preferable in all cases. Is there a
parameter or some sort of approach that can change this behaviour, so that
the point is only shown while the user is currently drawing something?
Ticket URL: <http://trac.openlayers.org/ticket/3315#comment:3>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
