[OpenLayers-Trac] Re: [OpenLayers] #3315: Problem with geometry handlers - doesn't stop showing a point under the cursor
OpenLayers trac-20090302 at openlayers.org
Tue May 24 18:14:41 EDT 2011
cursor
 Reporter:  mgleahy        |       Owner:  tschaub
     Type:  feature        |      Status:  new
 Priority:  minor          |   Milestone:  2.11 Release
Component:  Handler.Point  |     Version:  2.11 RC1
 Keywords:                 |       State:
Comment(by jorix):
 Replying to [comment:3 mgleahy]:
 > Is there a parameter or some sort of approach that can change this
 behaviour, so that the point is only shown while the user is currently
 drawing something?
 There is currently no way around it.
 This behavior appears with the ability to pan the map while drawing (and
 this can be avoided by using the {{{stopDown: true}}}, but the point
 continues to follow the cursor)
 The code of these handlers has had a lot of changes!!
Ticket URL: <http://trac.openlayers.org/ticket/3315#comment:4>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
