[OpenLayers-Trac] Re: [OpenLayers] #3315: Problem with geometry
handlers - doesn't stop showing a point under the cursor
trac-20090302 at openlayers.org
Wed May 25 02:58:40 EDT 2011
#3315: Problem with geometry handlers - doesn't stop showing a point under the
cursor
Reporter: mgleahy | Owner: tschaub
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Handler.Point | Version: 2.11 RC1
Keywords: | State:
Comment(by erilem):
> > I think the underlying problem is that the handler.drawing property no
longer exists or is being set to 'true' when there is an active drawing
for paths/polygons. This was being set in the Handler.Path mousedown
event for 2.10. In 2.11-rc1, 'this.drawing' is set to false in the
Handler.Point.finalize method...but it is otherwise not being set (as far
as I can tell).
> Yes, it's an oversight (In #3310 I suggest use it for internal use when
working freehand)
See #3316
Ticket URL: <http://trac.openlayers.org/ticket/3315#comment:5>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
