[OpenLayers-Trac] [OpenLayers] #3323: Handler.Path: Not always
clean the persistence
trac-20090302 at openlayers.org
Fri May 27 02:33:38 EDT 2011
#3323: Handler.Path: Not always clean the persistence
Reporter: jorix | Owner: tschaub
Type: bug | Status: new
Priority: trivial | Milestone: 2.11 Release
Component: Handler.Path | Version: 2.11 RC1
Keywords: | State:
Using example [http://openlayers.org/dev/examples/measure.html
measure.html] try:
* draw a line ending with a double click.
* press the shift key (freehand start)
* click, the measurement is correct 0.00 m, oops! but the line does not
disappear.
* do 3 clicks
* release the shift key
* draw a line ending with a double click, ok.
* draw a line ending with a double click, oops! the previous line
remains.
I think that is where the problem, is similar to #3310
Ticket URL: <http://trac.openlayers.org/ticket/3323>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
