[OpenLayers-Trac] [OpenLayers] #3576: Incorrect geometry passed to
measurePartial
trac-20090302 at openlayers.org
Tue Nov 15 08:41:16 EST 2011
#3576: Incorrect geometry passed to measurePartial
Reporter: lopez | Owner: tschaub
Type: bug | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Control.Measure | Version: 2.11
Keywords: measurepartial geometry | State: Review
This bug is evident when using '''immediate''' option for
OpenLayers.Control.Measure.[[BR]]
See
http://dev.openlayers.org/releases/OpenLayers-2.11/examples/measure.html
[[BR]]
Use "measure distance" and enable "use immediate measures".
If you move the mouse fast enough after adding a point to the measure, the
measurePartial callback gets a cached clone of how the measure geometry
looked like when the point was added. You can see this as the value for
the measurement is not updated correctly in the demo.
When a point is added the last component of the line and point following
the cursor will be on the same position. Since the callback is triggered
with a timeout, moving the mouse before the callback is invoked will
update the measure geometry but not the cached clone. The cached clone is
the geometry sent to the callback, which at invocation time is outdated.
This will give incorrect measurements.
Attached is a simple patch that fixes this.
Ticket URL: <http://trac.openlayers.org/ticket/3576>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
