[OpenLayers-Trac] [OpenLayers] #3544: Handler.Polygon interferes
with selectedFeatures when adding a hole
trac-20090302 at openlayers.org
Sat Oct 8 02:34:14 EDT 2011
#3544: Handler.Polygon interferes with selectedFeatures when adding a hole
Reporter: kylecronan | Owner: tschaub
Type: bug | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Handler.Polygon | Version: 2.11
Keywords: hole selected polygon | State:
Ordinarily the polygon handler has no effect on selected features when
used by the drawFeature control. However, the way it implements adding a
hole to an existing polygon is by removing its feature from the control's
layer, and it doesn't check selection. As a result, if you add a hole to a
selected polygon feature it will remain highlighted but no longer be in
its layer's selectedFeatures.
To reproduce:
1. create a map with a vector layer, polygon drawFeature control (with
holeModifier) and selectFeature control
2. draw a polygon
3. switch to select control and select the polygon
4. switch back to draw control and draw a hole inside the polygon
Ticket URL: <http://trac.openlayers.org/ticket/3544>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
