[OpenLayers-Trac] Re: [OpenLayers] #3061: Investigate,
and if possible implement more efficient tile positioning
trac-20090302 at openlayers.org
Tue Oct 25 09:39:04 EDT 2011
#3061: Investigate, and if possible implement more efficient tile positioning
Reporter: ahocevar | Owner:
Type: task | Status: closed
Priority: minor | Milestone: 2.12 Release
Component: Layer.Grid | Version: 2.10
Resolution: fixed | Keywords: mobile
State: Commit |
Comment(by ahocevar):
Replying to [comment:34 rangoy]:
> I am trying to use this (I currently test from the OpenLayers 3 git-
repo), and I am experiencing an a bit annoying artifact: In some browsers
there is a white bar between the tiles.
Are you seeing this with fractional zoom levels (e.g. 17.1) only, or also
with integer zoom levels? To try, use map.getZoom() in the debug console
on the client-zoom example.
Ticket URL: <http://trac.openlayers.org/ticket/3061#comment:35>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
