[OpenLayers-Trac] Re: [OpenLayers] #3061: Investigate, and if possible implement more efficient tile positioning
OpenLayers trac-20090302 at openlayers.org
Tue Oct 25 09:55:41 EDT 2011
  Reporter:  ahocevar    |       Owner:
      Type:  task        |      Status:  closed
  Priority:  minor       |   Milestone:  2.12 Release
 Component:  Layer.Grid  |     Version:  2.10
Resolution:  fixed       |    Keywords:  mobile
     State:  Commit      |
Comment(by rangoy):
 Replying to [comment:35 ahocevar]:
 > Replying to [comment:34 rangoy]:
 > > In some browsers there is a white bar between the tiles.
 > Are you seeing this with fractional zoom levels (e.g. 17.1) only, or
 also with integer zoom levels? To try, use map.getZoom() in the debug
 console on the client-zoom example.
 Only in fractional levels. The integer zoom-levels are correct.
Ticket URL: <http://trac.openlayers.org/ticket/3061#comment:36>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
