[OpenLayers-Trac] Re: [OpenLayers] #3495: GPX writer
trac-20090302 at openlayers.org
Tue Sep 13 12:24:03 EDT 2011
#3495: GPX writer
Reporter: pgiraud | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: general | Version: 2.11 RC3
Keywords: | State: Needs More Work
Changes (by marcjansen):
* state: Review => Needs More Work
Comment:
Some short notes from a first look at the patch:
* It seems as if you currently do not use the properties 'waypointsDesc'
or 'tracksDesc'
* there is no test for the second argument to write(), correct?
* in appendAttributesNode(): shouldn't the 'name' fallback to feature.id
instead of feature.attributes.id?
* in appendAttributesNode(): There currently isn't a switch whether you
are appending to a waypoint or a track, right? See first bullet.
* in buildTrkSegNode(): Could you please move the variable declarations
to the start of the function? This isn't a big issue, more of a
preference.
Ticket URL: <http://trac.openlayers.org/ticket/3495#comment:1>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
