[OpenLayers-Trac] [OpenLayers] #3631: Panel with Navigation control, mouse wheel zoom deactivated
OpenLayers trac-20090302 at openlayers.org
Mon Mar 5 17:28:53 EST 2012
 Reporter:  armin                    |       Owner:
     Type:  bug                      |      Status:  new
 Priority:  major                    |   Milestone:  2.12 Release
Component:  Control.Navigation       |     Version:  2.11
 Keywords:  mouse wheel zoom, panel  |       State:
 If I replace in the Panel control the "MouseDefaults" control with the
 "Navigation" control then the default mouse operation for the mouse wheel
 (zoom in/out) is deactivated if any other tool than the Navigation (e.g.
 the zoom control) is active in the panel.
 If I switch back to using MouseDefaults instead, then everything is fine,
 but this control is marked as deprecated... One can easily see this
 behaviour with the "panel.html" from the "examples" directory, replacing
 "MouseDefaults" with "Navigation".
Ticket URL: <http://trac.openlayers.org/ticket/3631>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
