[OpenLayers-Trac] [OpenLayers] #3632: Add propertyNames to getFeature control
OpenLayers trac-20090302 at openlayers.org
Mon Mar 5 17:33:25 EST 2012
 Reporter:  scaddenp  |       Owner:
     Type:  feature   |      Status:  new
 Priority:  minor     |   Milestone:  Future
Component:  general   |     Version:  2.11
 Keywords:            |       State:
 By adding propertyNames to getFeature it can be used in two circumstances
 with greater efficiency.
 1/ In combination with SLDSelect. This lets the server select and
 highlight complex geometry instead of downloading a geometry set by
 getFeature. The getFeature control can be used in tandem to select the
 desired property values (excluding geometry).
 2/ As a replacement for WMSgetFeatureInfo control. Only in geoserver 2.1.3
 trunk can GML response be limited by propertynames so getFeature can be
 more efficient.
Ticket URL: <http://trac.openlayers.org/ticket/3632>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
