[OpenLayers-Users] Popup Opacity issues
joanne cook
j.cook at oxfordarch.co.uk
Tue Apr 17 03:17:10 EDT 2007
Hi Bill,
Thanks for getting back to me. However, this didn't work for me. Not only that, but when I set it to map.events.register, it fired the popup event wherever on the map I clicked, including the zoom bar (so, coincidentally I can now fix the version that is slightly broken even if I can't work out why one does opacity and the other does not)
Cheers
Jo
Joanne Cook BSc MLitt AIFA MBCS
Information Systems Coordinator
Oxford Archaeology North
From: Bill Woodall [mailto:bwoodall at wardrobe.dhs.org]
Sent: Mon 16/04/2007 17:37
To: joanne cook
Subject: Re: [OpenLayers-Users] Popup Opacity issues
Hi Jo,
I believe you need to use the 'map' and not the layer in the line
In file "mapdata.thehumanjourney.net.htm":
line 57: wfs.events.register("click", map, function(e){
where as in
In file "test3.html":
line 45: map.events.register("click",map, function(e){
Hope that helps
...........Bill,
On Mon, 2007-04-16 at 14:57 +0100, joanne cook wrote:
> Hi All,
> I have two versions of a map, one which is a little broken, yet has an opaque popup, and another that does everything else I want but the popup seems to ignore the setopacity parameter. I have no idea why this might be. Could someone take a look at the code and enlighten me? These are both tested with firefox 2.
> Broken but opaque:
> http://mapdata.thehumanjourney.net/OpenLayers-2.3/examples/test3.html
> Working but not opaque:
> Many thanks
> Jo
This message has been scanned for viruses by BlackSpider MailControl - www.blackspider.com
