[OpenLayers-Users] openMNND demo
Chris Tweedie chrislist at narx.net
Tue Apr 17 21:42:55 EDT 2007
Hi Brad,
mod_proxy + a line of rewrite code is certainly the easiest way to proxy any kind of request ... although not the most secure (read: open proxy) :) There are a lot of examples around the web for generic cross-domain issues.
If some more advanced functionality is required, my tool of choice is PHP + curl but i only use this on secure services wherever authorisation is required. Whatever floats your boat i guess,
Chris
On Wed, 18 Apr 2007 11:29:07 +1000, "bradleyspencer" <brad at cubewerx.com.au> wrote:
> Christopher,
> I have not had any luck making a Python script work as a proxy host.
> Do you think an Apache forward Proxy would do the trick?
> Cheers,
> Brad Spencer
> General Manager
> CubeWerx Australia Pty Ltd
> ABN: 37 115 163 285
> Mob: +61 (0)404 841 131
> Tel/Fax: +61 (0)2 9481 7024
> mailto:brad at cubewerx.com.au
> http://www.cubewerx.com.au
> -----Original Message-----
> From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
> Sent: Tuesday, 17 April 2007 8:55 AM
> To: bradleyspencer
> Cc: Stephen Woodbridge; openlayers users
> Subject: Re: [OpenLayers-Users] openMNND demo
> On Tue, Apr 17, 2007 at 08:51:12AM +1000, bradleyspencer wrote:
>> Stephen,
>> Thanks for this and its is what I want to do. I had the same problem
> loading
>> your application down on my server to test it as I did with openMNND
> demo.
> I
>> can see the WMS layers fine but no WFS. I can only think there is
> something
>> I do not understand about the paths or something like that. See
>> http://demo.cubewerx.com.au/imaptool.html. Alternatively I am using a
>> different code base to you guys that have WFS working.
> http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#WhydoIneedaProxyHos
> t
> Regards,
Chris Tweedie
