[OpenLayers-Users] openMNND demo
Stephen Woodbridge woodbri at swoodbridge.com
Tue Apr 17 22:48:42 EDT 2007
Brad,
Just checking, but you do realize that you do not need a proxy if you
are going to setup your own wfs server. For example you can use the
remote examples that have already been provided to you as example. You
can see all the client code and do everything except host that demo on
your server without the proxy.
I setup my own wfs server for my data and then built my ld-test.html
script with some help from Christopher and by mimicing the openMNND demo
that was running from the openlayers site.
Maybe I'm missing the point but you seem to be fighting an issue that
does not have to be solved to get you pages working. I don't run a proxy
on my site, just the wfs server via /cgi-bin/mapserv
-Steve
bradleyspencer wrote:
> Christopher,
> I have not had any luck making a Python script work as a proxy host.
> Do you think an Apache forward Proxy would do the trick?
> Cheers,
> Brad Spencer
> General Manager
> CubeWerx Australia Pty Ltd
> ABN: 37 115 163 285
> Mob: +61 (0)404 841 131
> Tel/Fax: +61 (0)2 9481 7024
> mailto:brad at cubewerx.com.au
> http://www.cubewerx.com.au
> -----Original Message-----
> From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
> Sent: Tuesday, 17 April 2007 8:55 AM
> To: bradleyspencer
> Cc: Stephen Woodbridge; openlayers users
> Subject: Re: [OpenLayers-Users] openMNND demo
> On Tue, Apr 17, 2007 at 08:51:12AM +1000, bradleyspencer wrote:
>> Stephen,
>> Thanks for this and its is what I want to do. I had the same problem
> loading
>> your application down on my server to test it as I did with openMNND demo.
> I
>> can see the WMS layers fine but no WFS. I can only think there is
> something
>> I do not understand about the paths or something like that. See
>> http://demo.cubewerx.com.au/imaptool.html. Alternatively I am using a
>> different code base to you guys that have WFS working.
> http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#WhydoIneedaProxyHos
> t
> Regards,
> Christopher Schmidt
> MetaCarta
