[OpenLayers-Users] Changing icons in GeoRSS layer?
Gregor Mosheh
gregor at hostgis.com
Sat Aug 4 02:48:39 EDT 2007
Holmes, Charles V. wrote:
> Trying to add the marker with the addMarker
> method will probably solve your problem.
That's fine if I want to add a static marker. My goal here was to
replace all of the feature icons in-place. I did come up with a method
to replace all the RSS icons in-place, though. I copied and tailored
some code from Layer/GeoRSS.js, to create this:
var overlays = new OpenLayers.Layer.GeoRSS(...);
function setOverlayIcons() {
for (i=0; i<overlays.features.length; i++) {
var feature = overlays.features[i];
var size = new OpenLayers.Size(10,10);
var offset = new OpenLayers.Pixel(-(size.w/2), -size.h);
var icon = new
OpenLayers.Icon('theme/img/move_feature_on.png',size,offset);
var newdata = feature.data;
newdata.icon = icon;
var newfeature = new OpenLayers.Feature(overlays, feature.lonlat,
newdata);
var marker = newfeature.createMarker();
marker.events.register('click', newfeature, overlays.markerClick);
overlays.features[i] = newfeature;
overlays.addMarker(marker);
overlays.removeMarker(feature.marker);
Pretty straightforward: "clone" the Feature's data but swap in a new
Icon; create a new Feature and replace it in the layer; create a new
marker from the new Feature and place it; delete the old marker. Works
beautifully!
One can imagine all sorts of uses by slipping a little bit of
criteria-examining code around the creation of the Icon.
In our particular case for this project, the need is for the marker to
be determined dynamically, based on RSS content (a <icon> tag for each
item). So I won't be using this trick after all; I'll have to modify the
source code to set the icon during the RSS parsing.
Ah well; a learning experience of this caliber is never a waste of time. :)
Kudos to the OL team on the code, BTW. It's very comprehensible, easy to
thumb through and see what does what.
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
