[OpenLayers-Users] misaligned kamap tiles
Ben Brehmer
bbrehmer at refractions.net
Fri Aug 3 18:55:12 EDT 2007
Hello All,
I am in the process of converting a kamap application to use OpenLayers
and in doing so have run into an occasional tile loading problem.
If you have a look at the attached screen shot you will see one valid
tile (highlighted with firebug) and several broken (pink tiles).
The broken tiles are offset in the X and Y direction and are broken
because they are referencing an invalid path in the kamap generated cache.
Some other observations:
-All the broken tiles are always in the same row OR column
-The broken tiles always load after every single tile in the viewport
has loaded successfully. (ie. an extra row/column is loaded with broken
tiles)
-This is unrelated to the OpenLayers.IMAGE_RELOAD_ATTEMPTS setting since
the tiles are broken due to a incorrect image path (not that they are
failing to load on the first attempt)
Any tips or possible leads would be greatly appreciated. I guess my main
question is why would OpenLayers be trying to load extra columns/rows
after all the columns/rows have already successfully loaded?
Also,
Thanks,
Ben
My map and layer setup:
var options = {
scales: [30000000, 15000000, 7500000, 4000000, 2000000, 750000,
400000, 200000, 125000, 75000, 35000, 17500, 12000, 7500],
maxResolution: "auto",
minResolution: "auto",
units: 'm',
maxExtent: MAX_EXTENTS,
controls: [mouseEvents]
map = new OpenLayers.Map('ol_map', options);
layer_base = new OpenLayers.Layer.KaMap("Land",
"http://brock.simplymap.com/kamap/tile.php",
{g:
"__base__", map: "basemap.map", layers: "def", transparent: 'true',
mapid: '0'},
{tileSize:
new OpenLayers.Size(200,200), srs:'epsg:99999', format: "image/gif",
Opacity: 0.3, isBaseLayer: true});
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070803/622eec55/kamap_tile_load_problem2.jpg
