[OpenLayers-Users] misaligned kamap tiles
Tim Schaub tschaub at openplans.org
Mon Aug 6 14:22:40 EDT 2007
Hey Ben-
Ben Brehmer wrote:
> Hello All,
> I am in the process of converting a kamap application to use OpenLayers
> and in doing so have run into an occasional tile loading problem.
I've seen the problem you describe as well.  Can you make a ticket for
this in Trac?
http://trac.openlayers.org/wiki/FilingTickets
You can set me as the owner if you like.  It will likely not get
addressed before the 2.5 release - but I'll remember to look at it if
you put my name on it.
Alternatively, if anybody else uses the ka-Map layer, any help is
appreciated in supporting it.
Tim
> If you have a look at the attached screen shot you will see one valid
> tile (highlighted with firebug) and several broken (pink tiles).
> The broken tiles are offset in the X and Y direction and are broken
> because they are referencing an invalid path in the kamap generated cache.
> Some other observations:
> -All the broken tiles are always in the same row OR column
> -The broken tiles always load after every single tile in the viewport
> has loaded successfully. (ie. an extra row/column is loaded with broken
> tiles)
> -This is unrelated to the OpenLayers.IMAGE_RELOAD_ATTEMPTS setting since
> the tiles are broken due to a incorrect image path (not that they are
> failing to load on the first attempt)
> Any tips or possible leads would be greatly appreciated. I guess my main
> question is why would OpenLayers be trying to load extra columns/rows
> after all the columns/rows have already successfully loaded?
> Also,
> Thanks,
> Ben
> My map and layer setup:
>  var options = {
>    scales: [30000000, 15000000, 7500000, 4000000, 2000000, 750000,
> 400000, 200000, 125000, 75000, 35000, 17500, 12000, 7500],
>    maxResolution: "auto",
>    minResolution: "auto",
>    units: 'm',
>    maxExtent: MAX_EXTENTS,
>    controls: [mouseEvents]
> map = new OpenLayers.Map('ol_map', options);
>  layer_base = new OpenLayers.Layer.KaMap("Land",
> "http://brock.simplymap.com/kamap/tile.php",
>                                                            {g:
> "__base__", map: "basemap.map", layers: "def", transparent: 'true',
> mapid: '0'},
>                                                            {tileSize:
> new OpenLayers.Size(200,200), srs:'epsg:99999', format: "image/gif",
> Opacity: 0.3, isBaseLayer: true});
> !DSPAM:4033,46b71974171633327367457!
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
