[OpenLayers-Users] Performance Issue with multiple layers
Gregor Mosheh
gregor at hostgis.com
Mon Aug 6 10:44:12 EDT 2007
> What is slowing down the process?
Are you using the OpenLayers.js library as it was distributed, or the
hosted version, or did you "build" the compressed version of the
library? The compressed one loads a lot faster, particularly because it
incorporates all 75+ libraries into a single file, saving your browser a
lot of small downloads. That in itself may help significantly.
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
