[OpenLayers-Users] Tooltip Name City...?
Scott Davis
scott at davisworld.org
Thu Aug 16 12:08:20 EDT 2007
I'm working on a similar feature right now.
If you are trying to do this on a WMS layer, WMS supports a
GetFeatureInfo. Possible limitations:
1. It requires a click, not a hover.
2. This roundtrips to the server rather than doing a quick in-memory
thing
3. Your target is a single pixel if you are dealing with point data.
If you are rendering it as a 20 pixel circle, the center point is the
only thing that will trigger the GetFeatureInfo request.
WMS combines all layers into a flat sea of undifferentiated pixels.
For hovering, the app can't tell the difference between a city point
and the base layer it sits upon.
We're pulling items like this out of the base layer and into a Marker
layer. Currently (OpenLayers 2.4) you have a couple of options for this:
1. Programmatically add each feature via the API
2. Add a Boxes layer
3. Add a Text layer (tab separated values)
4. Add a GeoRSS layer
<http://trac.openlayers.org/wiki/Documentation> has more info on these.
Once these elements are features, you should be able to detect a
hover and pop up your tooltip.
I'm anxiously awaiting GeoJSON support -- it's coming to both
OpenLayers and GeoServer soon, but it's not here today.
HTH,
s
Scott Davis
On Aug 16, 2007, at 6:14 AM, Carlos Fernando Gonçalves wrote:
> Hi list.
> Help me.
> I would like to know if he is possible to use Mouseover in
> openlayers to representing the text you want shown inside the tip?
> The system with openlayers needs to show the name of the cities
> when an user to pass with mouse on the map.
> Best regards,
> Carlos FG
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
