[OpenLayers-Users] Openlayers with mapserv
Christopher Schmidt
crschmidt at metacarta.com
Mon Aug 20 18:23:18 EDT 2007
On Mon, Aug 20, 2007 at 06:13:52PM -0400, James McManus wrote:
> I made both those changes, but did not get an image. I had
> transparent:"true" which I got from an example. This seemed strange so I
> changed it to false. I now get the level selection menu and pink tiles,
> but no image. There are no errors in my error_log, but my access_log
> shows that I am issuing the mapserver command. However, I am not
> generating a png image in the cache (tmp) directory. If I use this
> mapfile outside of OpenLayers I produce a png, so permissions to that
> directory for apache is okay. Does OpenLayers use use IMAGEPATH in the
> mapfile to try and find the png image? It seems like an error message
> would be produced, say the image can not be found.
Right click on the pink image and 'view image' on it. It should be an
error message. See what it says.
Regards,
Christopher Schmidt
MetaCarta
