[OpenLayers-Users] Exception Error
Pierre GIRAUD
bluecarto at gmail.com
Tue Dec 4 06:50:36 EST 2007
Firstly, you should probably take a look at the apache error log to
exactly see what the server error is due to.
Secondly, you may try to install and/or load the apache2 mod_pyhton module.
Regards,
Pierre
On Dec 4, 2007 11:54 AM, R. Ortner
<reinhard.ortner at edu.fh-kaernten.ac.at> wrote:
> I tried "which phyton" and get /usr/bin/python. So i changed the first line
> in proxy.cgi in my /var/www/cgi-bin/proxy.cgi file to #!/usr/bin/python
> but i still get an internal server error when i try to call this file?!!
> David E. Reksten wrote:
> > On 04/12/2007, R. Ortner <reinhard.ortner at edu.fh-kaernten.ac.at> wrote:
> >> hi, when i type python i get:
> >> Python 2.4.3 (#1, Jul 26 2006, 20:13:39)
> >> [GCC 3.4.6] on linux2
> >> Type "help", "copyright", "credits" or "license" for more information.
> >> so i guess it is installed, but when i try to call the
> >> http://172.xx.xx.xx/cgi-bin/proxy.cgi i get an 500 Internal server error.
> >> do i have to change someting in the cgi script (first line is:
> >> #!/usr/bin/env python)
> >> how i can find out where python is installed?
> > On Linux, you can usually call "which python" from the command shell.
> > See also http://www.xs4all.nl/~carlo17/which/
> > Regards,
> > David
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> View this message in context: http://www.nabble.com/Exception-Error-tf4936210.html#a14148390
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
