[OpenLayers-Users] Exception Error
R. Ortner
reinhard.ortner at edu.fh-kaernten.ac.at
Tue Dec 4 08:31:43 EST 2007
Thats the error in the error_log:
[Tue Dec 04 13:19:01 2007] [error] [client 172.21.18.99] (2)No such file or
directory: exec of '/var/www/cgi-bin/proxy.cgi' failed
[Tue Dec 04 13:19:01 2007] [error] [client 172.21.18.99] Premature end of
script headers: proxy.cgi
but the file /var/www/cgi-bin/proxy.cgi defenitely exist, and in the
proxy.cgi the path to the phyton is the same as i get when i call "which
python".
I will try to install mod_python but shouldn´t it work with "normal" phyton
too?
thougt mod_python is basically faster but the functionality should be
basically the same in that case?
Pierre GIRAUD wrote:
> Firstly, you should probably take a look at the apache error log to
> exactly see what the server error is due to.
> Secondly, you may try to install and/or load the apache2 mod_pyhton
> module.
> Regards,
> Pierre
> On Dec 4, 2007 11:54 AM, R. Ortner
> <reinhard.ortner at edu.fh-kaernten.ac.at> wrote:
>> I tried "which phyton" and get /usr/bin/python. So i changed the first
>> line
>> in proxy.cgi in my /var/www/cgi-bin/proxy.cgi file to #!/usr/bin/python
>> but i still get an internal server error when i try to call this file?!!
>> David E. Reksten wrote:
>> > On 04/12/2007, R. Ortner <reinhard.ortner at edu.fh-kaernten.ac.at> wrote:
>> >> hi, when i type python i get:
>> >> Python 2.4.3 (#1, Jul 26 2006, 20:13:39)
>> >> [GCC 3.4.6] on linux2
>> >> Type "help", "copyright", "credits" or "license" for more information.
>> >> so i guess it is installed, but when i try to call the
>> >> http://172.xx.xx.xx/cgi-bin/proxy.cgi i get an 500 Internal server
>> error.
>> >> do i have to change someting in the cgi script (first line is:
>> >> #!/usr/bin/env python)
>> >> how i can find out where python is installed?
>> > On Linux, you can usually call "which python" from the command shell.
>> > See also http://www.xs4all.nl/~carlo17/which/
>> > Regards,
>> > David
>> > _______________________________________________
>> > Users mailing list
>> > Users at openlayers.org
>> > http://openlayers.org/mailman/listinfo/users
>> View this message in context:
>> http://www.nabble.com/Exception-Error-tf4936210.html#a14148390
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
> Users mailing list
View this message in context: http://www.nabble.com/Exception-Error-tf4936210.html#a14150614
