[OpenLayers-Users] Vectors with text
Pierre GIRAUD
bluecarto at gmail.com
Fri Dec 7 04:04:43 EST 2007
You should be aware that this work is still in progress. This is the
reason why it is in a sandbox.
Of course the sandbox code differs from the trunk with some files
added, what you correctly noticed.
The easier way to get it working locally is to download the sandbox code :
svn checkout http://svn.openlayers.org/sandbox/camptocamp/vectorSymbols/
Once again, this code continues to evoluate, some bugs are fixed,
functionnalities are added or removed. It won't be stable till it goes
into trunk if it does.
However, you can try it and I would be please if you can give feedback
as far I as I am the developer of this code.
Regards,
Pierre
On Dec 7, 2007 9:43 AM, Andy Dale <andy.dale at gmail.com> wrote:
> Hi,
> I want to be able to assign a label to a vector. I have found the following
> example
> http://dev.openlayers.org/sandbox/camptocamp/text/examples/vector-features-with-text.html
> I cannot get it to work locally. I have looked at the OpenLayers.js in the
> lib directory of the this example and found that i did not have the
> following files:
> Style.js
> Rule.js
> Rule/FeatureId.js
> Rule/Logical.js
> Rule/Comparison.js
> Format/SLD.js
> I downloaded these and then added them to the lib/OpenLayers.js jsfiles
> array, but I still cannot get it working.
> Can anyone point out what i am missing ??
> Thanks in advance,
> Andy
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
