[OpenLayers-Users] Vectors with text
Andy Dale
andy.dale at gmail.com
Fri Dec 7 04:23:44 EST 2007
Hi Pierre,
Thanks for the warning ;-) I will try to check in out from subversion when
I figure out how to configure it to use a proxy, and then give you some
feddback on it.
Cheers,
Andy
On 07/12/2007, Pierre GIRAUD <bluecarto at gmail.com> wrote:
> You should be aware that this work is still in progress. This is the
> reason why it is in a sandbox.
> Of course the sandbox code differs from the trunk with some files
> added, what you correctly noticed.
> The easier way to get it working locally is to download the sandbox code :
> svn checkout http://svn.openlayers.org/sandbox/camptocamp/vectorSymbols/
> Once again, this code continues to evoluate, some bugs are fixed,
> functionnalities are added or removed. It won't be stable till it goes
> into trunk if it does.
> However, you can try it and I would be please if you can give feedback
> as far I as I am the developer of this code.
> Regards,
> Pierre
> On Dec 7, 2007 9:43 AM, Andy Dale <andy.dale at gmail.com> wrote:
> > Hi,
> > I want to be able to assign a label to a vector. I have found the
> following
> > example
> http://dev.openlayers.org/sandbox/camptocamp/text/examples/vector-features-with-text.html
> > I cannot get it to work locally. I have looked at the OpenLayers.js in
> the
> > lib directory of the this example and found that i did not have the
> > following files:
> > Style.js
> > Rule.js
> > Rule/FeatureId.js
> > Rule/Logical.js
> > Rule/Comparison.js
> > Format/SLD.js
> > I downloaded these and then added them to the lib/OpenLayers.js jsfiles
> > array, but I still cannot get it working.
> > Can anyone point out what i am missing ??
> > Thanks in advance,
> > Andy
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20071207/943fe10b/attachment.html
