[OpenLayers-Users] Retrieving different coordinates
Hufjan
hufjan at web.de
Mon Dec 10 06:56:14 EST 2007
Hello Bart,
I experimented with my map trying to get coordinates for EPSG:4326 from
my EPSG:32632.Map. What I did is changing the request from
http://localhost:8080/geoserver/wms?bbox=277023.0864899452,5233434.01524883,923881.7291952965,6106592.061342626&styles=&Format=application/openlayers&request=GetMap&layers=topp:Deutschland&width=457&height=550&srs=EPSG:32632
to
http://localhost:8080/geoserver/wms?bbox=*5.508,47.117,15.619,55.104*&styles=&Format=application/openlayers&request=GetMap&layers=topp:Deutschland&width=457&height=550&srs=EPSG:4326
Then I get my coordinates in Lat/Lon.
But: I didn't want to convert my 'mappicture'. It should remain in the
same UTM-projection I rectified it to. So my result is just a half step
forward.
Coordinates fine, map declined :-(
I discussed this theme in the Geoserver-List as well. There I was told
about the proj4j-library - especially about Mike Adair sandbox
(http://trac.openlayers.org/browser/sandbox/madair/lib).
This is meant to reproject coordinates from UTM (for all SRS handeling
UTM?) to EPSG:4326.
But I was was only told where to find it. So far nobody seems to have
experience with it neither knows if it's working. I also didn't find any
tutorials how to deal with it.
Do you ever met this problem?
Best regards,
cuxland
Bart van den Eijnden (OSGIS) schrieb:
> Geoserver can reproject the GeoTiff for you to EPSG:4326. This is what OL
> uses by default.
> So just look at the examples/wms.html and add your Geoserver URL in there.
> What do you mean with retrieve coordinates? Maybe the MousePosition Control
> is what you are looking for. Add that Control to your Map and you'll see the
> coordinates on mouse over.
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Janes Huff <hufjan at web.de>
> Naar: openlayers users <users at openlayers.org>
> Onderwerp: [OpenLayers-Users] Retrieving different coordinates
> Datum: 29/11/07 10:51
>> Hello,
>> I must introduce myself as a Newbie that searched a week inside this
>> list getting more and more confused.
>> I'm simply looking to an answer for this question:
>> I loaded a GeoTIFF to Geoserver (UTM32N/WGS84 = SRS:32632). Is it now
>> possible to retrieve geographic coordinates (Lat/Lon/WGS84; SRS:4326) via
>> OpenLayers??
>> Just a hint where to find more information would be very helpful.
>> Exhausted (from searching) greetings,
>> cuxland
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
| Dipl.-Geogr. Janes Huff
| Wilhelmshavener Str. 30
| 10551 Berlin
| Tel.: +49(0)30 - 44 70 47 96
| Mobil: +49(0)176 - 23 43 30 99
| Fax: +49(0)1212-5-113-83-519
| Homepage: www.radinformix.de
| Skype: hufjan
| ICQ: 430988829
| Yahoo: cuxland
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20071210/85356a8b/attachment.html
