[OpenLayers-Users] Retrieving different coordinates
    Bart van den Eijnden (OSGIS)
    bartvde at osgis.nl
    Mon Dec 10 07:06:34 EST 2007
I have no experience with this code, but can confirm this is the way to go.
AFAIK this will probably make it into OpenLayers 2.6, so maybe it's still a
bit too early to attempt this (depending on your javascript skills
ofcourse).
Maybe someone else can give you more pointers.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Hufjan <hufjan at web.de>
Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>, openlayers users
<users at openlayers.org>
Onderwerp: Re: [OpenLayers-Users] Retrieving different coordinates
Datum: 10/12/07 09:56
> Hello Bart,
> I experimented with my map trying to get coordinates for EPSG:4326 from
> my EPSG:32632.Map. What I did is changing the request from
http://localhost:8080/geoserver/wms?bbox=277023.0864899452,5233434.01524883,923881.7291952965,6106592.061342626&styles=&Format=application/openlayers&request=GetMap&layers=topp:Deutschland&width=457&height=550&srs=EPSG:32632
> to
http://localhost:8080/geoserver/wms?bbox=5.508,47.117,15.619,55.104&styles=&Format=application/openlayers&request=GetMap&layers=topp:Deutschland&width=457&height=550&srs=EPSG:4326
> Then I get my coordinates in Lat/Lon.
> But: I didn't want to convert my 'mappicture'. It should remain in the
> same UTM-projection I rectified it to. So my result is just a half step
> forward.
> Coordinates fine, map declined :-(
> I discussed this theme in the Geoserver-List as well. There I was told
> about the proj4j-library - especially about Mike Adair sandbox
(http://trac.openlayers.org/browser/sandbox/madair/lib).
> This is meant to reproject coordinates from UTM (for all SRS handeling
> UTM?) to EPSG:4326.
> But I was was only told where to find it. So far nobody seems to have
> experience with it neither knows if it's working. I also didn't find
> any tutorials how to deal with it.
> Do you ever met this problem?
> Best regards,
> cuxland
> Bart van den Eijnden (OSGIS) schrieb:
>   Geoserver can reproject the GeoTiff for you to EPSG:4326. This is what
OL
> uses by default.
> So just look at the examples/wms.html and add your Geoserver URL in there.
> What do you mean with retrieve coordinates? Maybe the MousePosition
Control
> is what you are looking for. Add that Control to your Map and you'll see
the
> coordinates on mouse over.
> Best regards,
> Bart
> http://www.osgis.nl
> Van: Janes Huff <hufjan at web.de>
> Naar: openlayers users <users at openlayers.org>
> Onderwerp: [OpenLayers-Users] Retrieving different coordinates
> Datum: 29/11/07 10:51
>     Hello,
> I must introduce myself as a Newbie that searched a week inside this
> list getting more and more confused.
> I'm simply looking to an answer for this question:
> I loaded a GeoTIFF to Geoserver (UTM32N/WGS84 = SRS:32632). Is it now
> possible to retrieve geographic coordinates (Lat/Lon/WGS84; SRS:4326) via
> OpenLayers??
> Just a hint where to find more information would be very helpful.
> Exhausted (from searching) greetings,
> cuxland
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> | Dipl.-Geogr. Janes Huff
> | Wilhelmshavener Str. 30
> | 10551 Berlin
> | Tel.: +49(0)30 - 44 70 47 96
> | Mobil: +49(0)176 - 23 43 30 99
> | Fax: +49(0)1212-5-113-83-519
> | Homepage: www.radinformix.de
> | Skype: hufjan
> | ICQ: 430988829
> | Yahoo: cuxland
