[OpenLayers-Users] different coords format
R. Ortner
reinhard.ortner at edu.fh-kaernten.ac.at
Mon Dec 10 07:15:37 EST 2007
hi,
I´m trying to change the GetFeatureInfo request a little bit (to display a
ka-map layer query) but have some trouble with the coordinate.
I´m using basically this source code:
var request = window[id].getFullRequestString({
REQUEST: "GetFeatureInfo",
EXCEPTIONS: "application/vnd.ogc.se_xml",
BBOX: window[id].map.getExtent().toBBOX(),
X: e.xy.x,
Y: e.xy.y,
INFO_FORMAT: 'text/html',
QUERY_LAYERS: window[id].params.LAYERS,
WIDTH: window[id].map.size.w,
HEIGHT: window[id].map.size.h});
now the problem is, the information I get for X and Y is e.g.:
&X=314&Y=319
what I need is to change the coords to ka-map confirm coordinates in that
format:
&coords=474133.0773014716,181821.5684830197
I hope someone have an idea how i change the e.xy.x and the e.xy.y to geht
the coords format I need.
View this message in context: http://www.nabble.com/different-coords-format-tp14251884p14251884.html
